Replace Or Repair - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 11:45 AM   #1
Rewards Points: 18
replace or repair
I have a 30 year old Day and Night dual pack unit that has been giving me some problems. AC is still working, but not too well. had a buddy hook up some gauges and take some temperature readings and he is telling me it looks like an internal restriction in the liquid line. Here are the temps and pressures...
suction side pressure 56 lbs
high side pressure 325 lbs
temp going in to compressor 107 degrees
temp going out of compressor 230 degrees
temp out of condenser 135 degrees
temp out of evaporator 56 degrees
(superheat something like 80 degrees?)(not sure what that means)
Outside temp 102, inside temp about 75
I assume that if there is an unidentified restriction, it probably makes more sense to replace the unit then pay for extensive troubleshooting/repairs on a unit this old. Your thoughts? Thanks for your help...
valuator1956 is offline   Reply With Quote
Old 06-21-2012, 11:54 AM   #2
personally myself i could live with a room temp at 75 , unless the unit is working way to hard , and that you would see an increase in your electric , on the other hand try to get one more summer out of it
glambert25 is offline   Reply With Quote
Old 06-21-2012, 11:57 AM   #3
Just an FYI prices to replace systems are much cheaper in the fall/winter. This is peak season for a/c replacements, companies will get top dollar. If you can put it off for a couple months you may save a bundle.
wheelsup is offline   Reply With Quote
Old 06-21-2012, 12:16 PM   #4
Rewards Points: 18
unfortunately it is on a rental unit, so I might not have that option.
And how expensive is it to track down and fix a restriction? (assuming that that is what it sounds like to you)
Bob
Old 06-21-2012, 12:59 PM   #5
I would not recommend sticking any money into a 30 year old piece of equipment.
Old 06-21-2012, 02:52 PM   #6
HVAC Tech/Owner
Rewards Points: 604
Technow is offline   Reply With Quote
Old 06-21-2012, 10:01 PM   #7
Numbers do not make sense. your tech did not measure them right. Anyway, like all other people said, enjor your 75F, wait until the Summer is over then decide what to do.
clocert is offline   Reply With Quote
Old 06-23-2012, 11:23 AM   #8
Rewards Points: 18
Not sure why they don't make sense? Pressures? Temps? Can you give me any more info?
Old 06-23-2012, 11:25 AM   #9
Rewards Points: 18
save a bundle?
How much savings are we talking about? I am getting a quote for a 3 ton Rheem package unit for about 4k installed.
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General DIY Discussions 12 09-05-2011 09:46 PM
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 06:37 AM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 10:00 AM
Outdoor faucet - repair or replace? ETex2 Plumbing 2 01-19-2009 02:07 PM
Repair or replace baseboard? handbanana Painting 9 04-09-2007 06:40 AM
