Replace Old Thermostat With A New One - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 11:42 AM   #1
Replace Old Thermostat With a New One
I bought a new Honeywell RTH7000 Series thermostat a while ago and have never installed it. I was wondering if I could get some advice on how to wire it in. Everything in the pictures is a little clear. I have questions about the W2 connection. It looks like a blue wire comes out of the wall and into W@ and then there is a jumper from W2 to E. I have included pictures of the old and new thermostat connections.
Replace Old Thermostat With a New One-img_5175.jpg   Replace Old Thermostat With a New One-img_5179.jpg
jamesduanejr is offline   Reply With Quote
Old 02-19-2012, 11:45 AM   #2
HVAC Tech/ Browns Fan
W2 to Aux then E to Emerg. Aux is for heat pump
Tator1076 is offline   Reply With Quote
Old 02-19-2012, 11:46 AM   #3
You need add wire to e only on stat then e only indoor unit
Old 02-19-2012, 12:41 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
R = R jumpered to RC
C = C
G = G
O = O
Y = Y
W2 = Aux jumpered to E
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-19-2012, 12:53 PM   #5
hvacttech126, just to be clear:
w2 on old unit to aux on new unit with a jumper to e?
Old 02-19-2012, 12:59 PM   #6
AKA HVACTECHFW
yes, that is correct
IT IS WHAT IT IS
Old 02-19-2012, 01:01 PM   #7
Make sure you cut the power to the unit also.
You can short your transformer out.
Tinner105 is offline   Reply With Quote
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
Replace 3 wire electric baseboard thermostat Bhurl5 HVAC 4 11-27-2011 08:07 PM
double pole thermostat for kickspace heater lee12 Electrical 3 12-09-2010 12:52 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
