Old 09-27-2012, 11:34 AM   #16
Replace my furnace now or later? 80% vs 95%? HELP
Thanks for all of the replies - lots of good info! So it looks like I should for sure replace it - if the retrofit of the needed exhaust/supply isn't a major ordeal, I will plan to go with a 95% unit.
In regards to getting the correctly sized unit, I am wondering if you could consider the BTUs of the current (old) furnace and the way it acted in various temperature extremes, and then could gauge how much of a furnce I really need. I realize that doing a load calc get good info, but I am trying to see if more real-world / existing data would trump a hypothetical calculation.
The current furnace (1988) is 116k BTUs. I live in a 1600 ft2 tri-level house. The lower level is half finished, and half un-insulated crawl space. On the coldest winter days (-25 F), the furnace would run almost non-stop when the thermostat was set to 70.. On the other colder days, it would cycle on and off - the longest span of time that it would be off would be 15 minutes. Seemed like it would cycle on and off a lot.
Could I assume that the old furnace may have been 25% efficient? If so, could I assume that I was only getting/using 87k BTUs of the 116k BTUs, in which case, a 95k or 100k 95% furnace would be OK?
Another wrinkle in all this is that I just insulated the walls of my crawl, which I assume will lesson the need of the furnace.
In all, I am ok with getting a little bit more furnace than I need becuase we are contemplating a small addition (400 ft2) that will need to be heated.
Or, should I forget all this and do a proper load calc?
Lastly, are these install prices ($3600 for a 100k BTU 80%, $4400 for a 100k BTU 95%) out of line?
Thanks so much for all of your help!
Mr Blotto is offline   Reply With Quote
Old 09-27-2012, 05:07 PM   #17
An old Tradesmen
Guessing at how efficient your current furnace is, won't give you any real world info. You would also need to clock the meter, and know the BTU content of the gas.
Old 09-27-2012, 05:57 PM   #18
you would also have to have an accurate heat loss calc and know the comparable "degree days" to know the true seasonal efficiency over the heating season..ARE YOU KIDDING ME! gets a little complicated ay!
Don't sweat it..you will definitely save .. BIG TIME with new Hi Eff Furnace. It will put a smile on your wallet.
techpappy is offline   Reply With Quote
Old 09-27-2012, 06:08 PM   #19
To answer your other Q's a 100 K hi eff sound s good, esp considering add on..However ...and this depends a lot on your location but, IMO, I think those prices may be about 15 -20% higher than normal so, you may be able to easily get 10% off..Again there are many details we may not be aware of and those prices might be an absolute bargain. The most important key is to have a reputable installer!
Old 09-27-2012, 10:59 PM   #20
Best to wait and see.
Natural gas prices are getting so low, I got an email the other day saying that all the meters are going to be collected and sold for scrap.
Also, you could just turn on your kitchen oven in the morning. This has 100% efficiency. What is for breakfast? Cinnamon rolls, coffee cake, etc.
cleveman is offline   Reply With Quote
Old 09-27-2012, 11:04 PM   #21
Missouri Bound's Avatar
If there is a nameplate on the furnace with the btu information you can figure out the efficency from that information.
Do you want it your way or the right way?
Old 09-28-2012, 12:21 AM   #22
existing unit from 1988 so, figure 75% at 100K = 75,000 btuh output therefore 100 K input at 95% = 95 K output so, existing was nicely sized at 75 K output PLUS future additional 400 sq ft/25% extension BUT at higher eff build requiring only extra 15 - 20% capacity/15000btuh max So I figure 95,000 btuh output shoul do it. RIGHT? Besides that's what the estimator quoted as well.
How to replace furnace drain trap burnzyd HVAC 2 04-07-2012 10:26 AM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Furnace blew up, need to replace heat and air with single unit. d_Random HVAC 2 02-06-2007 05:18 PM
