Old 10-12-2012, 05:39 PM   #1
Replace the limiter on my Amana furnace & my thermostat shorted out.
The limiter replacement was very easy - 4 wires. As soon as I tuned on the heat via the thermostat - the thermostat shorted out. What next? Any suggestions? Now the air doesn't work either. Thank you!
empireman is offline   Reply With Quote
Old 10-12-2012, 06:48 PM   #2
Bet the limit is touching the cabinet and causing a direct short to ground. Or... you didn't break the tab separating the high and low voltage on the limit and just fried every 24v component. Hope not.
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
New Thermostat and Furnace Not Working Right Vegas Resident HVAC 1 12-06-2007 07:42 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
