Replace Lennox HVAC Thermostat With Honeywell Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 11:58 AM   #1
Replace Lennox HVAC thermostat with honeywell thermostat
Have Lennox elite furnace with heat pump. Thermostat wires red, white, yellow,green, blue. Thermostat went south. Bought a honeywell digital prog RTH2310B. Wire directions Red to RH jumpered to RC. Yellow to Y, Green to G, White to W and Blue terminated. My heat pump doesnt come on now. Can anyone please verify connections.
wvudan1954 is offline   Reply With Quote
Old 07-14-2012, 04:13 PM   #2
An old Tradesmen
Rewards Points: 6,124
Did you turn the power off before you changed out the thermostat.
Old 07-14-2012, 10:04 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Doesn't look like heat pump wiring.... as Beenthere asked
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Replacing a Carrier thermostat with a Honeywell thermostat Fred Lambrerth HVAC 2 07-11-2012 06:02 PM
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 03:11 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 02:30 PM
