Replace Johnson Control With Fenwal - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2014, 04:55 PM   #1
Replace Johnson Control with Fenwal
Hi Guys:
I have very little experience, but reading these posts and finding a "direct" replacement for the G776RGD-11 box, I found and purchased a Fenwal 35-63J303-117. Although the connectors have moved around, they are well labeled and not a problem. This is on a Lennox furnace C23-51
However, there is a thin rubber hose going to the Johnson unit that is not air, but has a wire in the middle; the same post on the Fenwal unit is quite different and has no contact post in the middle.
What now?
[Posted elsewhere with wrong subject ]
citabriabob is offline   Reply With Quote
Old 03-16-2014, 06:59 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
That is the high voltage spark ignition wire. Fenwal has an adaptor for it and supply it on the control. Read the install info. Usually people buy the Honeywell kit from cozyparts.com.
I found the install info and you need to use the adaptor on the control Rajah type and figure out how to attach the ignition wire to it. I have not run into it yet.
Old 03-16-2014, 07:57 PM   #3
Thanks, Yuri:
I did not get installation instructions. I did download the product info (4 pages), with no hint of an adapter or any other instructions. Do you have a link to it?
Old 03-16-2014, 08:23 PM   #4
Hvac Pro
yuri's Avatar
I Googled this and it should be your control. On top of it is a gold colored spark plug adaptor Rajah adaptor. Usually you have to strip some of the spark plug wire insulation and then shove the wire inside and then crimp it so it attaches to the adaptor. If you bought it from ee-bayy then a lot of the time it is used and junk. Did it come in a sealed box? If not I would order the Honeywell kit from cozyparts.com
http://www.fenwalcontrols.com/utcfs/...2035%2063J.pdf
Help rewiring control system for multistage heat pump ink HVAC 12 12-10-2012 10:23 PM
Fan Speed Control tev9999 Electrical 3 12-04-2012 12:28 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Dishwasher Control Panel Zen Nomad Appliances 0 10-02-2010 12:00 PM
Replacing inside air control unit - have to replace outside as well? yalej HVAC 2 04-29-2009 12:46 PM
