Replace Goodman Draft Inducer - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 10:50 PM   #1
Rewards Points: 14
Replace goodman draft inducer
the draft inducer on my goodman furnace needs to be replaced. I have purchased a rotom replacement (recommended replacement) for the same. the old motor had 2 wires coming out from it - one black & one white. the replacement motor does not have any wires; rather 2 male spade connectors. Can someone help me figure out which one should be white and which should be black?
It is a
1/30hp, 3000 RPM
1.4 amps, 115 volts
motor.
any help will be appreciated.
thank you!
aptcloe is offline   Reply With Quote
Old 10-04-2012, 05:20 AM   #2
An old Tradesmen
Rewards Points: 6,492
Doesn't matter.
Old 10-04-2012, 10:37 AM   #3
Rewards Points: 14
Thanks - i was afraid either it would burn or then it would turn the other way around (Reverse) if the wires were switched.
Old 10-04-2012, 04:34 PM   #4
An old Tradesmen
Nope. Single phase motors require more then just changing those 2 wires to change direction. And as far as which wire to which, its a bit like a light bulb, it doesn't care.
Replacing draft inducer cost of DIY vs pro WillK HVAC 30 01-23-2012 11:37 PM
Draft Inducer Motor Assembly 70Flyer HVAC 19 01-20-2012 04:28 PM
furnace draft inducer motor classichd04 Appliances 2 12-30-2011 11:14 AM
American standard Draft inducer noise jprince HVAC 3 01-24-2011 10:38 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
