-   -   Replace goodman draft inducer (http://www.diychatroom.com/f17/replace-goodman-draft-inducer-158892/)
aptcloe 10-03-2012 09:50 PM
the draft inducer on my goodman furnace needs to be replaced. I have purchased a rotom replacement (recommended replacement) for the same. the old motor had 2 wires coming out from it - one black & one white. the replacement motor does not have any wires; rather 2 male spade connectors. Can someone help me figure out which one should be white and which should be black?
It is a
1/30hp, 3000 RPM
1.4 amps, 115 volts
motor.
any help will be appreciated.
thank you!
beenthere 10-04-2012 04:20 AM
Doesn't matter.
aptcloe 10-04-2012 09:37 AM
Thanks - i was afraid either it would burn or then it would turn the other way around (Reverse) if the wires were switched.
beenthere 10-04-2012 03:34 PM
Nope. Single phase motors require more then just changing those 2 wires to change direction. And as far as which wire to which, its a bit like a light bulb, it doesn't care.
