Old 10-24-2005, 11:58 PM   #1
Default Replace furnace, coil and duct system
Iam getting price quotes to replace existing hot air gas furnace, coil and duct system in the attic for second floor. House is a 2 story house with a basement. There is a seperate heating/cooling system in the basement for first floor, which does not need anything done.
One dealer wants to install 2 round flex ducts (10 in. and
12 in.) instead of traditional rectangular duct (for trunkline). Existing duct is
10 in by 14 in and existing furnace is single stage Rheem
100,000 BTU. Whole system is 18 years old.
He will use existing round supply flex ducts with dampers and connect boxes.
He says, he is doing it for 2 years and this provides better air flow and more balanced system,
as there will be two additional dampers with these two round ducts.
According to him this reduces the price of the duct system by $700.
He will install Rheem 2 stage 75000 BTU furnace with digital thermostat.
Does anybody has any experience with this type of installation.
Any problems with this type of Installation.
What percentage of homes use this system.
Should I go with this type of installation or stay away from it ?
Any reponse will be greatly appreciated.
Thank you very much.
sps123 is offline   Reply With Quote
Old 01-06-2006, 10:44 PM   #2
I recently joined the chatroom and found this question without reply. I really can't help since I am searching ans. also, but have you resolved what to do?
John Scavdis is offline   Reply With Quote
Old 01-07-2006, 12:56 PM   #3
weinstall.ca
Post
sTay away from any flexible ducting it causes way too much static pressure with the ridges
weinstall.ca
allan is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
