Old 04-18-2011, 09:56 AM   #1
Question
Replace Fan Motor
My a/c was working fine but it did need to be cleaned. I had a tech out to clean the coils and clear drain lines. Three days later the fan stopped running, now they say I need to replace the motor. What do you think? Is this just a coinsidance or is it possible he tech made a mistake and got the motor or wiring wet? What if anything can I do to prove mistake?
Maureen693 is offline   Reply With Quote
Old 04-18-2011, 10:20 AM   #2
Replace Fan Motor
Which coil ? inside or outside ? which fan ? inside or outside ? Did the tech check the capacitor(s) ?
clocert is offline   Reply With Quote
Old 04-20-2011, 09:20 AM   #3
Replace Fan Motor
The coils and fan outside. Yes the capacitators are fine he tested both inside and out..
Old 04-20-2011, 11:35 AM   #4
Hvac Pro
Replace Fan Motor
The outdoor motor is weatherproof/watertight so he could not damage it. Probably it is moving more air now that the coil is clean and the motor was weak and the extra speed it is now running finally croaked it.
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 01:25 PM
Replace Furnace Blower Motor Jenks HVAC 1 04-24-2010 08:09 AM
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 10:57 PM
Blower motor wiring help!! atvguy64 HVAC 4 02-04-2008 09:27 PM
Replace a furnace blower motor dadncharge HVAC 2 12-06-2007 10:42 PM
