Old 03-03-2009, 01:22 AM   #1
Replace Expansion Tank
Should this be replaced? There is only this drain valve and a plug towards the back. No air pressure valve?
I read that they should be free of water? I drained about 2 gallons of water out.
Also I think this limit switch is bad it's not cutting the boiler off when temp on t stat is reached?
Carloscda40 is offline   Reply With Quote
Old 03-03-2009, 06:42 AM   #2
An old Tradesmen
A. That tank needs to be able to draw air in while its drained, or else, it won't drain.
The water you got out, was just what it took to put it into a vacuum.
B. The second picture doesn't show a limit. Your water temp controls are in the front of your boiler.
Old 03-03-2009, 01:50 PM   #3
So is that bad?
Is this the limiter?
Old 03-03-2009, 03:59 PM   #4
An old Tradesmen
Thats your aquastat.
Can't tell if its bad from here.
Need to test it.
Is it allowing the water temp to rise more then 10° above set temp?
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
will a expansion tank help with water hammer wazeaz Plumbing 3 07-13-2008 12:51 AM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 11:53 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
poss. expansion tank? pingers7 HVAC 7 03-21-2007 08:42 AM
