-   -   Replace Expansion Tank (http://www.diychatroom.com/f17/replace-expansion-tank-39543/)
Carloscda40 03-03-2009 12:22 AM
http://i492.photobucket.com/albums/r...IMG_0978-2.jpg
Should this be replaced? There is only this drain valve and a plug towards the back. No air pressure valve?
I read that they should be free of water? I drained about 2 gallons of water out.
Also I think this limit switch is bad it's not cutting the boiler off when temp on t stat is reached?
http://i492.photobucket.com/albums/r...IMG_0980-1.jpg
beenthere 03-03-2009 05:42 AM
A. That tank needs to be able to draw air in while its drained, or else, it won't drain.
The water you got out, was just what it took to put it into a vacuum.
B. The second picture doesn't show a limit. Your water temp controls are in the front of your boiler.
Carloscda40 03-03-2009 12:50 PM
So is that bad?
Is this the limiter?
http://i492.photobucket.com/albums/r...IMG_0984-1.jpg
beenthere 03-03-2009 02:59 PM
Thats your aquastat.
Can't tell if its bad from here.
Need to test it.
Is it allowing the water temp to rise more then 10 above set temp?
