Old 03-06-2012, 11:53 PM   #1
Replace baseboard radiator with in floor heat
We have a 50yo ranch that has a newer natural gas boiler with baseboard heaters throughout the house. I attached a simplified diagram for how our system is plumbed.
I are redoing our bathroom down to the studs and I would like to put some type of in/underfloor heating in rather than the baseboard radiator.
I would likely use warmboard or a similar product, or staple up plates below the sub floor for the actualy heat transfer.
What I am more concerned about is the actual water flow, and if there are potential issues with just replacing this unit. For instance, I think I would have to install a bleed valve above the floor level to purge the air from the loop... I'm sure there are other concerns.
Thanks.
farmy87 is offline   Reply With Quote
Old 03-07-2012, 05:39 AM   #2
An old Tradesmen
The radiant would have to be its own loop to work right.
Old 03-07-2012, 06:44 AM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... It'll wanta be on it's own loop, probably with a mixer valve....
Seems I remember that baseboards want 180°, 'n in-floor wants something cooler, like 160° or so...
The bleeder can be put 'bout anywhere, downstream of the radiation...
Still Very doable, just not as easy as plug, & play...
You'll Love it when ya get it done...
Replace 3 wire electric baseboard thermostat Bhurl5 HVAC 4 11-27-2011 09:07 PM
Install baseboard over/around existing trim of bathroom vanity? sunshine22 Remodeling 2 02-24-2011 09:39 AM
Baseboard Heater Size Advice nightheron Electrical 4 12-05-2010 08:33 PM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
