Replace The AC With New Furnce? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 06:58 PM   #1
replace the AC with new furnce?
I need to replace my 20+ year old gas furnace but the AC compressor was replaced 8 years ago. Should I replace both? The furnace will be 95% efficient but the AC is 11 seer. I am getting different opinions from contractors. Help!
teddyz16 is offline   Reply With Quote
Old 11-13-2010, 07:43 PM   #2
Knowing what part of the world you're from would help. AC in Alaska might last 40+ years and one on the gulf of mexico might be doing great to see 10 years.
Old 11-14-2010, 05:39 AM   #3
An old Tradesmen
Rewards Points: 8,142
It also depends where area of Philly PA he lives in.
Teddy. While 11 years isn't really that old for an A/C. Now is probably the time to replace it. As you may be able to take advantage of the tax credits available.
Depending on your electric rate(PECO ? ALSO HAS REBATES FOR HEAT PUMPS) you may want to consider getting a dual fuel system. And save on you heating bill also..
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
