Replace 65 Year Old Furnace With 18 Year Old? (yes... Furnace)? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 02:20 PM   #1
Replace 65 year old furnace with 18 year old? (yes... furnace)?
Never mind. Just too frustrating
frascati is offline   Reply With Quote
Old 02-22-2013, 02:23 PM   #2
Rewards Points: 14,026
Nope, nothing came up.
Old 02-22-2013, 02:25 PM   #3
how
Rewards Points: 1,104
I'm all for it but my wife says my chances are unlikely.
how is offline   Reply With Quote
Old 02-22-2013, 02:25 PM   #4
If your suggesting replacing a 65 year old unt for one that's 18 years old I do not see that working out in your favor.
Old 02-23-2013, 06:39 AM   #5
Rewards Points: 1,216
How Bout replacing a 65 year old furnace with a brand new one.? Now that's the way to go.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following 3 Users Say Thank You to COLDIRON For This Useful Post:
ben's plumbing (02-23-2013), hvactech126 (02-23-2013), joecaption (02-23-2013)
Old 02-23-2013, 07:27 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,646
Ayuh,.... That sounds 'bout the same as replacin' a Bald tire, with a Flat tire....
Bondo is online now   Reply With Quote
The Following 2 Users Say Thank You to Bondo For This Useful Post:
ben's plumbing (02-23-2013), COLDIRON (02-24-2013)
Old 02-23-2013, 09:56 PM   #7
Rewards Points: 582
why on earth would you even consider such a dangerous plan....I see no good or any logic at all in that process.....that like replacing a broken window with a screen ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 02-23-2013, 10:51 PM   #8
Rewards Points: 986
I'm pretty sure it is a joke of some kind. I don't get it, but it sounds like a joke.
Toller is offline   Reply With Quote
Old 02-24-2013, 04:02 AM   #9
An old Tradesmen
Rewards Points: 7,818
Could just upload the pics to here directly, instead of using a hosting service.
Old 02-24-2013, 05:42 AM   #10
Rewards Points: 194
Replacing a 65 yr old furnace with a high efficiency furnace is a good idea. I wouldn't put an 18 yr old furnace in.
Larryh86GT is offline   Reply With Quote
Old 02-24-2013, 05:45 AM   #11
An old Tradesmen
Some people refer to a boiler as a furnace. Some 18 year old boilers would be more then ok to use.
Old 02-24-2013, 06:16 AM   #12
I agree with you been for an 18 year old boiler that's already in service and operating several years trouble free. Maybe
But to go to all the trouble removing a 65 year old unit and installing a 18 year old boiler no.
All the piping, wiring, setup, flue work, inspection, testing , no warranty,
Not for me that's for sure.
I don't think anybody should put that kind of labor, materials and money into that system.
Let me say I am open to all comments but I will never change my mind on this subject regardless.
Just think after all that beautiful work and set up nothing but trouble and calls in the middle of the night, week ends and holidays.
Old 02-24-2013, 06:26 AM   #13
An old Tradesmen
He's DIY it. So he has his labor. If he gets it for a hundred bucks or so. No real money loss.
How about a boiler that was in service for 26 years. Then removed and stored for 4 years, and then put back in service at another location. And has only had one problem in 5 years(a loose wire at the 3 HP burner motor). A new boiler would have cost $12,500.00 for this commercial place. They got the used one for a grand. Oh, and a new boiler for $12,500.00 didn't include the 4.3 million BTU burner.
The Following User Says Thank You to beenthere For This Useful Post:
RWolff (07-11-2013)
Old 02-24-2013, 07:00 AM   #14
From the limited (nothing) information in post #1 I can't tell if he's DIY or just asking the question.
Either way even DIY no I wouldn't do it. It's still a lot of work for an 18 year old boiler.
DIY removing a 65 year old boiler and installing a 18 year old boiler a disaster waiting to happen.
The answer is no.
Didn't know the OP was referring to an Commercial/Industrial Boilers. Thought this site was residential. Even with the example you proposed I would think that would be more money and time wasted-ed installing such a large boiler with much more piping wiring , safeties, permits, inspection, start up. All to have a 18 year old boiler.
Old 07-11-2013, 10:21 AM   #15
Apologies to all.
It's been so long since I posted this and have not revisited the forum since then. I can't remember, honestly, what the original post was. But it looks like I might have been in a really short temper that day and was irritated by the first few responses. Must have edited out the original message in disgust.
In any case. It's months later. The 300lb behemoth rests safely (from us) 'neath many more tons of scrap steel at Padnos reclamation. I dismantled it and loaded it in the pickup myself. Yes, there were a couple of 10x12x1/4 inch asbestos pads sandwiching the burner/plenum mounts. I soaked the crap out of them in clear acrylic paint and let it harden overnight. Then extremely carefully, with fully rated respirator, triple bagged them and properly disposed of them at a local hazardous waste site.
When dismantling I discovered that the exhaust, routed up the chimney, ran directly through the return air plenum on its way. Could have been to avoid having to route another pipe outside of the furnace on its way to the exit, or it might have been some mediocre attempt at recouping a little bit of heat on its way out. In any case, there was a 1.5 inch round hole rusted through this pipe right in middle of the fresh air return plenum. That had to contribute to the winter blahs a bit in this house.
Now the 18 year old furnace I'm replacing this with was indeed free.
It's in excellent condition and the efficiency sticker indicates 92.8. My old furnace was probably under 60 percent. The date I determined by the spec sheet inside the bottom panel. a-1995 at the middle bottom. I believe it was installed new approx four to five years after that date according to the friend who gave it to me. He installed geothermal on his 80 acre ranch and had this under a tarpaulin in the garage.
So under the heading of "nothing to lose" if it gives me poor service or poops out too early I will have made the space and provided the ductwork to simply slide-in a brand new identically dimensioned Rheem/Ruud in just a few hours. The old one should net 20 bucks in scrap.
These are the drawings I'm emailing around for estimates. The gray portions exist. The blue are needed to join the new furnace to supply and return boxes above. The 6" wide cabinet next to the furnace holds a 25x20x5 filter element. I was going to replace it with a thinner version for replacement cost sake (those fat ones are scary expensive) till I shopped a bit and discovered that they aren't bad if you buy a dozen at once and just store them.
Of four contacted, only one has gotten back to me yet with a price of 251.80. I neglected to ask what gauge he's using. Another place asked me which I required, 22 or 24? For three small pieces I ought to just go 22ga. Can't be much more in material cost.
Anyone know if these components can be purchased online, custom made, shipped flat, for less expense? Only one site I discovered did just that, but when contacted they did not sell retail.
So there's the (much) fuller version of the original post. My apologies again for leaving it to seed earlier.
I've thrown all this out there for comment. I've never done any HVAC. I have a nephew who worked in HVAC for ten years who will help me assemble the pieces and seams. Don't know if he's certified for inspections but I suppose that is a must for something like this for insurance purposes.
Any thoughts?
Replace my furnace now or later? 80% vs 95%? HELP Mr Blotto HVAC 21 09-27-2012 11:21 PM
Replace furnace before relocation? dac122 HVAC 1 04-09-2012 03:39 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
May I replace my own furnace??? avro1 HVAC 40 03-01-2010 08:53 PM
Should I replace this Furnace Carloscda40 HVAC 16 02-25-2009 08:53 PM
