Replace 3-speed Blower Motor With 5-speed? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 12:03 PM   #1
replace 3-speed blower motor with 5-speed?
I would like to replace my 115V, ¾ hp, 1075 rpm, 3-speed, direct-drive blower motor with a more efficient one. It is mounted beneath the burner of my 1993 York oil furnace which has heat pump coils mounted on top. The most efficient 3/4hp, 1075 rpm motor I have found is an 8 amp A.O. Smith, # FDL1076V1, which has 5 speeds. Another forum recommended also an Emerson EcoTech which would use only 5 amps, but is 5-speed also.
Is a 5-speed motor easily adaptable to a system designed for 3-speed motors?
Thanks for your advice.
heiss is offline   Reply With Quote
Old 02-18-2011, 01:45 PM   #2
HVAC Tech/ Browns Fan
Yes just cut end of unused speed and wire nut it.
Tator1076 is offline   Reply With Quote
Old 02-18-2011, 01:47 PM   #3
If you run fan all time you should install a evergreen fan motor.
Old 02-18-2011, 02:16 PM   #4
motor
Three speed or five speed doesn't matter if your only using 2 of the speeds. If your motors nameplate says 1075 RPM then this is your high speed. Just don't use slower speeds then your maching needs to run efficient or you do yourself no good and could damage your unit.
college A/C is offline   Reply With Quote
Old 02-19-2011, 04:49 AM   #5
An old Tradesmen
Rewards Points: 7,802
Your not going to get a drop in your electric bill by installing a new PSC direct drive motor in your furnace.
The amp rating on them is not what they actually draw when running. That varies/depends on how much work the motor is actually doing. The listed amp draw is what they will draw when actually doing their rated work load.
Before you invest in a new blower motor. You may want to check the actual amp draw of your current blower motor(must be done with blower panels closed/on so its running under its normal operating conditions. Along with checking the actually running voltage.
Old 02-19-2011, 12:23 PM   #6
Thanks to all of you for your advice. I've looked at as much information as I could find on the web about such things as Evergreen and EcoTech motors and wiring. In thinking over the risks of me getting the wiring or speeds wrong, the uncertainties of savings, and the costs of hiring a technician and upgrading to an ECM motor for an 18 year old furnace, my gut tells me to buy a 3-speed, 1075 rpm, PSC replacement motor as a standby for a snowstorm emergency like I had four years ago. I have already bought an “Ultimate” blower wheel puller. Learning some basics about motors and blower systems has been enjoyable and will undoubtedly help me make the best decision when furnace replacement time arrives. Thanks again.
Old 02-19-2011, 12:46 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 114
Buy a matching capacitor with the new motor. Not necessarily the same size as now. Will have the rating on the motor box. An ECM replacement motor will cost over $600-800 installed and never pay for itself with your unit.
Old 02-19-2011, 03:39 PM   #8
Will do. Thanks for the professional confirmation.
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 01:03 PM
Low speed blower won't work in auto mode Eric F HVAC 16 10-29-2008 05:24 PM
Variable Speed Blower qnzkrew HVAC 2 01-03-2008 06:14 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 10:01 PM
