Old 11-06-2009, 08:31 PM   #1
Peg doesn't have heat
Default Repair or replace gas heat unit and power vent
I have a 20 yr old Heil gas heater that is part of a split system vented to a Tjernlund HSUL power vent in my basement. The power vent has been making more noise for about a year and has become very annoying. Depending on where the straps are holding it, it can cause noise all thru the vent and the heater cabinet. Now it sounds like an airplane. Anyway, now my heating unit won't stay on and makes a popping noise. The hvac repairman says it is the gas valve. He has quoted me $585 to replace the power vent and the gas valve. He says that the new power vent will have a control board which I don't even use so that is why the price is high.
Do you know if the HSUL which is no longer made can be oiled or repaired in any way to stop making so much noise?
And is it best to just pay for a new heating unit rather than repair one that is 20 yrs old? If so, then what brand and efficiency do you recommend for Tenn which isn't very cold. My repairman gets the best prices on Rheem and installs them the most often. Are there any particular features you would select on a new heating unit or avoid? The two that are in stock now are Rheem RGRA and RGRL. A neighbor thought Trane was the best and that is what she bought. Consumer Reports says they are all about the same as far as reliability.
Thanks in advance for your opinion.
PegTN is offline   Reply With Quote
Old 11-06-2009, 08:40 PM   #2
old pro
I really like Rheem and even though I deal mostly high end Lennox units the Rheem is a good basic furnace. Not many problems with circuit boards and the model with the spark ignition is very reliable. At 20 yrs old the heat exchanger may fail soon and Heils are bad for that issue. I would invest in a new furnace and check about the government incentives for high efficiency units. Trane parts are silly expensive in my experience.
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Laundry is a fact of life. Many homes run at least one load of laundry on a daily basis. And when you factor in children and pets, you could do even more laundry than that. With your washer and dryer running that much, it's important to keep the noise... Read More »
Hi this is Howard Fleischmann with Community Tire in Phoenix, Arizona on behalf of Expert Village. In this segment we will remove the purge tank and disconnect the fuel and the vent hoses from the gas tank. Here you see the technician unbolting the purge... Read More »
A short ram intake is a very simple version of a cold air intake system, which reduces the air temperature inside an internal combustion engine. A short ram intake system usually consists of a short metal pipe and an air filter, which combine to increase... Read More »
Most propane BBQ grills are versatile and easy to use and operate. By reading the owner's manual for your particular propane BBQ, and by following a few basic safety tips, you will be able to light it consistently. Read More »
Power Save Device capt2 Electrical 50 11-10-2009 09:06 PM
Rheem power vent blower motor life expectancy? windowguy Plumbing 4 09-04-2009 01:39 PM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 05:23 PM
Home Outside A/C Unit Won't Power Up ldeneale HVAC 3 10-29-2008 06:37 PM
unit is trying to heat in cooling mode... gotdirtygrout HVAC 1 07-12-2008 12:00 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
