Old 05-27-2012, 06:19 PM   #1
repair leak in trane ar 11 evap coil #twg 030a140b1
is repair possible ?, what type of solder and flux is required?
grumpy4517 is offline   Reply With Quote
Old 05-27-2012, 07:20 PM   #2
I'm Your Huckleberry
Depends on where the leak is.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following 2 Users Say Thank You to Doc Holliday For This Useful Post:
hvactech126 (05-28-2012), plummen (05-27-2012)
Old 05-27-2012, 11:14 PM   #3
if its copper you need silfos... soft solder is not good
carmon is offline   Reply With Quote
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
Access to CPC13H evap coil.. bginvestor HVAC 1 06-27-2008 10:40 PM
vinyl compressor cover petroman HVAC 4 04-14-2008 04:52 PM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 06:30 PM
Will a 4T Evap. Coil w/50' Lineset suck in 21 oz R22 at 500 microns? hennyh HVAC 1 02-21-2007 12:49 PM
