Repair Info For Luxaire HAMD-F0365A - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2007, 11:58 AM   #1
Repair info for Luxaire HAMD-F0365A
Air conditioning unit just quit. Clicks and hums, I think it is the fan motor maybe? Is there a part list/repair manual anywhere for this unit?
Many thanks!!
womanmarine is offline   Reply With Quote
Old 09-23-2007, 12:24 PM   #2
Eibwen
I would pull off the service panel and check for a wiring diagram inside.
Check the blower relay, fan switch, and motor...
Is the outside unit coming on?
Sammy is offline   Reply With Quote
Old 09-23-2007, 01:17 PM   #3
This is the outside unit that's not working. The inside blower is working on the air handler. The outside unit just refuses to come on, it is humming and the fan doesn't come on although it clicks like it wants to. The top is HOT!! I think it is the fan motor causing the heat, but I don't know.
Thanks so much for your reply!!
Old 09-23-2007, 01:43 PM   #4
Eibwen
If its the outside uinit I would shut everything down and call a repair company tomorrow. Could just be a capacitor on the motor for the compressor but if you leave it run, it may burn up the outside unit.
