-   -   Repair info for Luxaire HAMD-F0365A (http://www.diychatroom.com/f17/repair-info-luxaire-hamd-f0365a-11770/)
womanmarine 09-23-2007 12:58 PM
Air conditioning unit just quit. Clicks and hums, I think it is the fan motor maybe? Is there a part list/repair manual anywhere for this unit?
Many thanks!!
Sammy 09-23-2007 01:24 PM
I would pull off the service panel and check for a wiring diagram inside.
Check the blower relay, fan switch, and motor...
Is the outside unit coming on?
womanmarine 09-23-2007 02:17 PM
This is the outside unit that's not working. The inside blower is working on the air handler. The outside unit just refuses to come on, it is humming and the fan doesn't come on although it clicks like it wants to. The top is HOT!! I think it is the fan motor causing the heat, but I don't know.
Thanks so much for your reply!!
Sammy 09-23-2007 02:43 PM
If its the outside uinit I would shut everything down and call a repair company tomorrow. Could just be a capacitor on the motor for the compressor but if you leave it run, it may burn up the outside unit.
