Repair Copper Tubbing - Or Replace Longer Run - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 06:40 PM   #1
Repair copper tubbing - or replace longer run
Situation: Trane A/C, less than 4 years old, began to loose gas about a year after installation. The company came out one time - could not find the leak topped off system, paid for service. 7 - 8 months later, low gas, changed the condenser coil still under warranty, paid labor and gas. About the same period of time later, low gas again.
I called someone else - for obvious reasons - and, after using a detector in all accesible places, he suspects the leak is in the wall, possibly caused by baseboard nail (house is modular, sheetrock was already up before A/C, but not the baseboards, chase already builtin to the attic). The strategy is to open the wall in a couple of places around the baseboards (two story house) and take a peak.
I am concerned that the leak may be due to the original installer crap work where he joint the tubbing somewhere in the wall, so I am thinking that after cutting my walls the leak will not be found.
I am thinking about just replacing the run in the wall from where it enters and exits the chase - approximately 25 feet, and skip the time for wall exploring.
Thoughts? Cost of one vs the other, especially if the leak is not found during the first look into the walls?
Regards
frank otero is offline   Reply With Quote
Old 12-23-2012, 08:27 PM   #2
Rewards Points: 582
Regards
if it has not been done already.. why not vac out system isolate condenser, coil and test line set before you make any rash decisions....shoulden't take that long for a qualified company to tell if line set is leaking......it should have been done for proper troubleshooting to find trouble from the start...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (12-24-2012)
Old 12-23-2012, 09:01 PM   #3
Rewards Points: 614
find and fix the leak......guessing usually costs more money in the long run....
carmon is offline   Reply With Quote
Old 12-24-2012, 05:41 AM   #4
Thanks Ben.
Once it is isolated to the lineset, though, would it be better to start cutting into the wall (two stories worth) to pinpoint the exact leak location to seal it, or would it be better (expense, possibility of a second undiscovered leak) just to run a new line set
Old 12-24-2012, 06:56 AM   #5
Rewards Points: 1,214
I agree with Ben, lets see if we can find the leak first before getting to far ahead.
Sometimes it's difficult to isolate the coil from the line sets because there's no valves on them.
Find a good mechanic with a CAN DO attitude that won't quit until the leak is found.
I wouldn't call back the installing Company they don't care about their customers.
If that was my installation it would be my obligation to find and fix that thing for a reasonable cost not continuing to gouge you.
As a matter of fact that kind of thing is a challenge to me to fix and feel good afterward for you and me.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
ben's plumbing (12-24-2012)
Old 12-24-2012, 09:26 AM   #6
Roofmaster
Rewards Points: 2,172
one weird thing is that it apparently held pressure for a whole year after installation. Maybe solder used instead of Braze, and vibration cracked solder?
In any event it sounds like all here are correct isolate each component and place under pressure. If each holds, it was a connection.
Alternately, and I leave this up to the HVAC pros. If a leak would cause a change in temperature right at the place where it is leaking, charge unit, run and look at everything at night with an IR camera. If the place where it leaks shows up as hotter or colder then you will be able to see it with IR. You might even see it on the surface of the chase. I can very clearly see where my wall studs are in the winter with IR, Studs are colder than insulation.
Just a thought.
Old 12-24-2012, 11:22 AM   #7
Just a thought.
A good leak detector in capable hands will always be better.
To detect a temp change a leak would have to pass enough refrigerant to to cause a temp diff. Something that large would be audible..and would leak out quicker..much quicker...than the OP's system.
hvaclover is offline   Reply With Quote
Old 12-24-2012, 03:06 PM   #8
Rewards Points: 582
Thanks Ben.
yes if it is for sure the line set ...it may be easier and cheaper to replace it by another route....but you have to be sure its the line set ..if not you will run another line set only to have the same thing going on ...ben sr
Old 12-24-2012, 03:09 PM   #9
Rewards Points: 582
Thanks Ben.
we don't put fittings into a place we can't get too.they make bending tools for that purpose all fittings are exposed ...ben sr
Old 12-24-2012, 08:19 PM   #10
Very thankful for your replies, gents.
I suspect this leak is quite small since it takes a long time for me to notice the unit is not putting out. In this case, when isolating/pressurizing components, how much time would you need to detect a loss of gas with such small leak?
Merry Christmas
Old 12-24-2012, 08:26 PM   #11
Rewards Points: 582
I suspect this leak is quite small since it takes a long time for me to notice the unit is not putting out. In this case, when isolating/pressurizing components, how much time would you need to detect a lose of gas with such small leak?
Merry Christmas
we would do a vacuum test on the line set ..isolated from condenser and coil...pending on size of leak..maybe 20 minutes to 1 1/2 hours... hard to tell ..but it will show up if its leaking...ben sr
Old 12-24-2012, 10:49 PM   #12
“why not vac out system isolate condenser, coil.”
Just curious how do you isolate the condenser and the coil?
Hardway is offline   Reply With Quote
Old 12-26-2012, 06:59 AM   #13
Another way to find stubborn small leaks is to make sure theres refrigerant in the system, then build the pressure up to name plate test pressure with nitrogen then use an approved calibrated leak detector.
You' ll find it.
ben's plumbing (12-26-2012)
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
torch down roof repair or replace? ohmiahgod81 Roofing/Siding 2 09-23-2012 02:25 PM
Repair or Replace 13 yr old Furnace with Cracked Heat Exchanger Thor73 HVAC 33 11-12-2011 09:14 PM
4x4 post splitting ... repair? or replace? edwinhome9 Building & Construction 36 04-12-2011 10:20 PM
Repair or replace gas heat unit and power vent PegTN HVAC 1 11-06-2009 07:40 PM
