Repacing HP Condenser With Straight Cool. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 01:32 PM   #1
Repacing HP condenser with straight cool.
I currently have 3T Goodman heat pump with a hole in the compressor. A friend is replacing his 3T straight cool system with higher SEER equipment.
Can I use his straight cool condensor with my heat pump air handler if I replace the thermostat? Based on my research both are 10 SEER units.
We primarily use gas to heat, but would like to use the emergency heat strips as backup.
Can I wire this up with a straight cool thermostat and activate the heat strips when the thermostat is set to heat.
Any help would be appreciated.
bama7x57 is offline   Reply With Quote
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Pre-charge on goodman straight cool protechplumbing HVAC 31 11-10-2008 09:10 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 11:02 AM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 05:59 PM
