Removing Old Water Heater Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 01:49 PM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
Removing old water heater vent
Here is what it looks like in the attic.
The water heater is relocated, now I am thinking of using the roof opening for a bathroom vent.
What would it take to remove this?
Could be asbestos, so I need to take the appropriate precautions.
picflight is offline   Reply With Quote
Old 08-26-2011, 03:51 PM   #2
An old Tradesmen
Rewards Points: 7,746
What does it look like in the basement where the water heater connected to it.
Old 08-26-2011, 04:08 PM   #3
Pretty sure this is asbestos! Use caution! Am a Journeyman Sheet metal worker and see lots of this! Asbestos only dangerous if Airborn, you can soak it down before cutting to stop it from getting into the air. (or as i prefer - Hire someone to remove it) As for changing it over once chimney is removed - Very easy. Use exsisting roof flashing, purchase C-vent (snaplock) in size to fit as snug as possble. you will also need new raincap and storm collar in that size. Pipe to fan with C-vent and insulate. If u need to reduce size from flashing size to fan outlet size, purchase a pipe increaser 4"->6" and do so inside attic. Also if fan is to be mounted so that the housing of fan goes into the attic you will need to get a Vapor Barrier boot to go over top of fan and tie it into exisiting vapor barrier above drywall and under roof truss.
Tin2Win is offline   Reply With Quote
Old 08-26-2011, 04:16 PM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
The water heater was in a closet in the laundry room. Inside the closet it has been patched over.
The round patch is where the vent was.
Old 08-26-2011, 04:26 PM   #5
An old Tradesmen
Ok. It looks like asbestos paper/insulation on the pipe. As above, wetting it keeps it from becoming air born. The you can remove it.
Old 08-26-2011, 04:34 PM   #6
Busy DIYer
picflight's Avatar
Rewards Points: 150
I don't believe there should be any cutting involved. I think I can get it dislodged at the bottom and then pull it out through the roof. I will have to get someone to help me on this.
Old 08-26-2011, 07:41 PM   #7
What is c-vent? Is it a 3 wall pipe?
Master of Cold is offline   Reply With Quote
Old 08-26-2011, 08:45 PM   #8
Single wall vent.
hvac benny is offline   Reply With Quote
Old 08-27-2011, 04:01 AM   #9
Busy DIYer
picflight's Avatar
Rewards Points: 150
Originally Posted by hvac benny
Single wall vent.
Can you please post a link to product, I was unable to find.
Old 08-27-2011, 11:32 AM   #10
I'm not sure what sort of information you're looking for on C-vent. C-vent is heavy gauge, single wall venting that can be used as a vent connector only. It requires 6" clearance from combustibles. If you're planning on doing any gas appliance venting of your own, stick to b-vent for both the vent and the vent connector(s).
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
