Removing Old Oil Boiler And Radiators - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 05:52 AM   #1
Removing old oil boiler and radiators
So I recently had a new HVAC system installed (heat pump/gas furnance packaged system). My old system consists of an oil boiler and radiators. I am going to remodel the kitchen and expand into the room where the boiler is located so I need to remove it. The wife also wants the old cast iron radiators removed. So my question is how do I go about this? Here is what I am thinking:
1) Disconnect boiler from electrical, water supply and from oil lines.
2) Drain boiler using drain valve at bottom of boiler (New Yorker, ~ 20 years old)
Now the rest I am unsure of
3) crawl under house (crawl space) and cut piping to radiators one at a time. use buckets to catch water that drains from each radiator.
4) cut pipes so radiators can be pulled up from floor
5) either remove radiator as whole unit (guessing they are very heavy, most are 3' but one is 5-6') or gently break using sledge hammer
6) patch holes in hardwood floors
7) take cast iron to scrap yard to recycle
So any thoughts or advice? HVAC company wanted around $800 to do the job.
71Whaler is offline   Reply With Quote
Old 05-28-2009, 06:41 AM   #2
An old Tradesmen
Rewards Points: 8,192
Your correct on most of it.
You'll find a union fitting on each side of the rad that you can screw apart to disconnect them from the piping.
You can cut the tie rods that hold the rads together, and pry the sections apart.
WARNING:
Lay down tarps when you remove rads from house.
Also, use rags in all openings.
You don't want the black gooey grime in those sections on your floors.
Or your wife may decide to become a widow.
Old 05-28-2009, 06:58 AM   #3
Thanks for the info. I will check on the union fittings when I get home though I bet they are going to be fun to disconnect as the house is over 75 years old and the radiators are original.
I hear you about the tarps. We had the oak hardwood floors redone when we moved in 2 years ago and they look great. I mess them up and I'll be sleeping the yard.
Can you use a pry bar to seperate the sections after cutting the tie rods or do you need to hammer them apart? Someone told me that you need to use a sledge.
Thanks again.
Old 05-28-2009, 07:04 AM   #4
An old Tradesmen
Prybar.
Pried a lot of them apart with just a screwdriver, after the rods are cut(yea, it was a big screwdriver).
Sledge hammer is to break them.
Not needed to pry them apart.
Old 05-28-2009, 07:14 AM   #5
Thanks. I appreciate the replies.
Boiler stays on. Carloscda40 HVAC 23 03-04-2009 03:59 PM
Need Help I Have a BOILER PROBLEM mikerouse1989 Plumbing 7 02-01-2009 05:07 PM
Boiler Troubles *I Need Help Please* mikerouse1989 HVAC 4 02-01-2009 11:59 AM
Converting Steam Radiators To Hot Water johnpar HVAC 4 07-30-2008 03:34 PM
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 06:18 PM
