Removing Old Lennox Thermostat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 11:37 AM   #16
An old Tradesmen
Rewards Points: 7,372
It doesn't say it can handle 2 stages of aux heat. But I can't tell from the specs they provide.
Old 09-04-2011, 11:54 AM   #17
I'm no hoax expert, but I don't think what I'm looking got is as complicated as "two stages of aux heat". Merely a setting that says: "shut off the ac when the temp reaches the temperature that is set, and turn on when the temp goes only one degree above that setting" (rather than turning off the ac when the room temp reaches a full degree BELOW the set temp, and turning on when the room temp gets 2 or 3 degrees above that setting). I'd just rather the ac come on more frequently for shorter amounts if time. If that requires "two stage" something or other then I'm totally lost. Thanks.
124sport is offline   Reply With Quote
Old 09-04-2011, 12:07 PM   #18
An old Tradesmen
LOL... Sorry, was thinking of another thread when I replied.
I'm not fond of Hunter thermostats. Make a lot of money replacing them though.
Old 09-04-2011, 02:55 PM   #19
Ahh...ok. Lol.
Old 09-04-2011, 03:16 PM   #20
Check out ritetemp website.
Master of Cold is offline   Reply With Quote
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Lennox Furnace not kicking on unless thermostat is turned off then on sharkbait HVAC 14 12-31-2010 11:27 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Lennox thermostat question TrishP HVAC 4 12-20-2009 09:37 AM
