Removing Old Lennox Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 07:06 PM   #1
Removing old lennox thermostat
I bought a digital thermostat but am stumped as to how to remove the old lennox stat. Only numbers are inside: 9549 E8. There are no screws visible and if I pry from behind, or in between the base layers, I feel like I'll break it. Thanks.
124sport is offline   Reply With Quote
Old 08-28-2011, 07:11 PM   #2
fabrk8r
fabrk8r's Avatar
Remove the 3 small straight slot screws and the thermostat will come off the sub-base.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-28-2011, 07:51 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Turn the breaker to the furnace off before removing any wires. Whichever wire is on RH or RC terminal will be hot, 24 volts. If that wire touches anything while live you stand the chance of blowing the fuse on furnace board. Just a minor inconvenience but still more work than neccassary if it blows.
Under those three screws there'll be two more holding that base to the wall.
Doc Holliday is offline   Reply With Quote
Old 08-28-2011, 10:54 PM   #4
Thanks. I looked at those but the have contacts mounted through them so figured that wasn't it. But, will try tomorrow with breaker off of course.
Old 08-29-2011, 07:29 PM   #5
Done. Thanks.
Old 08-29-2011, 07:37 PM   #6
fabrk8r
fabrk8r's Avatar
You're welcome!
Thank you for letting us know how things worked out for you.
I hope the new thermostat is everything you hoped it would be.
Old 09-03-2011, 01:16 PM   #7
Actually, I think I'm gonna put on the old mercury based lennox. This thing (honeywell) stinks. It seems like it runs the ac forever. I guess cause its trying to get the temp down a full degree below the setting or something. Anyhow...we never felt so cold or so hot with the old thermostat. Thought this would be better for a newborn.
Old 09-03-2011, 06:10 PM   #8
AKA HVACTECHFW
Rewards Points: 1,208
it maybe a setting in the stat or it is a cheapo stat. post the model number. You should not get wild temperature swings with a digital stat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-03-2011, 06:21 PM   #9
An old Tradesmen
Rewards Points: 6,570
Newborns/babies/infants. Are not uncomfortable at the same temps as adults are.
Post the model number of the new thermostat you have.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (09-03-2011)
Old 09-03-2011, 08:36 PM   #10
RTH2310 Programmable Thermostat. It was $50 at Walmart but with a $25 rebate so I guess it is a cheapo. Doesn't look like there is any adjustment/setting for this (ie- change when it turns on or turns off in relation to thd temperature setting. For example, if I set it at 72, it seems to want to take the room temp to 71 before shutting off. likewise it seems like it won't turn on until it gets to 74. I'd rather it shut off at 72, and turn on at 73).
Old 09-03-2011, 09:03 PM   #11
AKA HVACTECHFW
so, yes, that is not a good stat IMO. I would recommend pro series Honeywell stats.
IT IS WHAT IT IS
Old 09-03-2011, 09:04 PM   #12
An old Tradesmen
50 dollar tstats are cheapo's.
Move up to a 7500 series, it will have a tighter temp tolerance.
Old 09-03-2011, 09:59 PM   #13
So am I looking for something with a "high/low" setting or "setpoint/desired temp" setting? (I saw those phrases in the specs on some of the higher end honeywells I googled). I want the ability to tell it when to kick on and off in relation to the temp I set zbd just need to know the proper "lingo" to look for. Thanks a lot guys. I'll bd taking this off soon.
Old 09-03-2011, 10:06 PM   #14
An old Tradesmen
Honeywell doesn't allowed you to set a differential. Some of the Luxpro does though.
Old 09-04-2011, 11:25 AM   #15
This looks like the only one I can find that allows this (in terms if what's readily available at home improvement stores)
http://www.lowes.com/pd_331377-79-44...&stop_mobi=yes
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Lennox Furnace not kicking on unless thermostat is turned off then on sharkbait HVAC 14 12-31-2010 12:27 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Lennox thermostat question TrishP HVAC 4 12-20-2009 10:37 AM
