Removing Humidity From Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 06:14 PM   #1
removing humidity from basement
I was wondering if i could add a small vent in my return in the basement to help remove some of the humidity when running the AC in the summer. I would close the vent during the heating system. Opinions? Thanks
Yamvmax is offline   Reply With Quote
Old 06-02-2009, 08:16 PM   #2
Rewards Points: 502
You are not likely going to remove anywhere near enough humidity this way.
Your best option is to purchase a dehumidifier.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 06-02-2009, 08:29 PM   #3
An old Tradesmen
Rewards Points: 6,540
If you lwer your basement humidity, you could also increase your living area humidity.
Takes a large amount of air wxchange to remove humidity.
Portable dehumidifier will work better.
Old 06-03-2009, 07:56 AM   #4
Don't know if your basement is musty or moldy smelling like some, but adding a return to the basement can circulate those odors around.
Dehumidifiers are designed specifically to remove larger quantities of moisture.
dac122 is offline   Reply With Quote
Old 06-03-2009, 10:10 AM   #5
Rewards Points: 292
Beenthere: I had a return leak (now sealed) in my basement. I believe it contributed to my still humid basement. So my question to you is, does using a dehu in the basement also cause an increase humidity in the living area?
V
veesubotee is offline   Reply With Quote
Old 06-03-2009, 10:13 AM   #6
Rewards Points: 502
Dehumidifiers remove moisture in the air and release it as water to a drain or sump pump pit.
Removing moisture from the air lowers humidity...so in your question to beeenthere, did you mean LOWER the humidity in the living area?
-Andrew
DIY hobbiest
Old 06-03-2009, 10:29 AM   #7
An old Tradesmen
If you use a humidifier in your basement. It will help with the humidity in your liing areas.
A large part of your air infiltration into the living/occupied areas comes through the basement.
So by lowering its humidity, you help to lower the humidity in your living areas.
Help removing stink from basement kazmiekr General DIY Discussions 8 10-30-2008 11:15 AM
Basement humidity myca HVAC 6 09-01-2008 10:01 AM
high humidity in basement orange HVAC 17 08-20-2008 02:24 PM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 07:31 AM
