Removing Hot Water Baseboard Heaters. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 10:36 PM   #1
Removing hot water baseboard heaters.
I recently purchased a house that the hot water heat had been converted to a heat pump. The baseboard heaters were not removed. I think they are ugly. Should I remove them? Or, is there a possible future use? Currently, oil and gas are too expensive to use hot water heat. I could buy a wood boiler, but electricity would have to get a whole lot more expensive than it is now. Given the fact that I also have a wood stove insert in my fireplace for supplemental heat. Is solar a possible in the future? Give me your thoughts....
Sandy1000 is offline   Reply With Quote
Old 07-22-2008, 11:05 PM   #2
oops, did I do that!
Removing them is fairly simple, but whats behind them is probably ugly too. I know what you mean, I would remove them, and deal with the new paint, patch and carpeting.
Personaly, I dont see solar home heating in the near future. Not until a less bulky, and more efficient storage system comes around.
Cash in the copper and aluminum and get a windmill/generator. Just a thought.
8 Ball is offline   Reply With Quote
Old 07-23-2008, 09:07 AM   #3
one determined mama
We have an old baseboard hot water system in our 50's house, I dread having to removing it but can't wait to remove those hideous baseboards. I hope it all goes well for you Good luck!! Keep us up to date!
mudpaw is offline   Reply With Quote
Old 11-02-2008, 12:34 AM   #4
Thumbs up
ugly baseboard heaters
I had a house full of these ugly things. It seems they are permanently installed to the wall. My contractor wanted $70 an hour to replace them with an estimate of 3 full days of work.
I ended up getting an easy solution at baseboardheatercovers.com
Amazing what a difference they made. Did the entire place myself in 45 minutes. Even cost less than the contractors labor quote!
Highly recommended way to renovate ugly baseboard heaters.
pmonger is offline   Reply With Quote
Old 11-02-2008, 04:41 AM   #5
The heaters and boiler are removed!
I determined that the water going to the boiler was turned off, and the only water would be that which was remaining in the pipes. I gently started removing the relief valve on a upstairs pipe and there was no water. I cut the pipes off and pulled the nails out of the heater covers. Downstairs, I cut the pipes in the crawl space because they did have water in them. Some sanding and sheetrock mud fixed the walls. Replacing small sections of wood flooring, replacing, and finishing fixed the floors. The floor repair was worth getting those ugly raditors gone. I sold the copper and metal for $65.
The boiler was cut from the pipes, partically dismanteled, and handtrucked out. I gave it to a neighbor for parts if he needed to fix his boiler. Now I have a nice work space with that boiler gone.
Thanks for info; I'm onto other remodeling projects.
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Advice - Tankless Water Heaters sandy2982 Plumbing 13 05-09-2008 10:27 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 04:59 PM
Air in hot water baseboard - help! heydobbs HVAC 6 12-08-2006 05:08 PM
