Removing Gas Valve/pilot Control - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-12-2008, 09:18 PM   #16
Is it the pin holding the burner in place under the valve the only thing stopping
the valve from revolving free of the manifold?
hvaclover is offline   Reply With Quote
Old 12-12-2008, 11:53 PM   #17
The manifold is too tight of radius for the new valve to spin around to tighten on it. In order to use it I need to take the dial assembly off but it requires a special bit on the screw.
Fuzzybunny is offline   Reply With Quote
Old 12-13-2008, 07:51 AM   #18
I found the screw type. Tamper resistant torx. Any reason I should not tamper with it?
Old 12-13-2008, 08:49 AM   #19
Did you try to push the knob in to see if it would clear or does the lower knob body strike the manifold?
DO NOT DISASSEMBLE NEW VALVE!!!!!!!!!!!!!!!!!!!!
HOUSE GO BOOOM IF YOU DO!
Old 12-13-2008, 03:58 PM   #20
Is BOOOM bad? Lol.....just kidding....I don't want to get into the valve just the dial assembly. I will try pushing in the knob and see if it clears.
Thanx for the advice
Old 12-13-2008, 08:22 PM   #21
What the hell you using for heat in the mean time?
i have this horrible image of your poor family shivering in heavy clothing while you figure this thing out.
Old 12-14-2008, 05:39 PM   #22
We have a 4 year old Amana that is the main house heat. This one was put in when they did a build out to heat the master bedroom, bath and half of my man cave and another bedroom. I have a gas fireplace in the Mbedroom so we light it up when we are in there for any length of time.
I did take some pics of the new valve on the manifold. It looks like the cover for the valve and the dial are the only things I'd need to remove temporarily but not take apart the valve itself. There is no other way unfortunately. Sorry they are a lil blurry, they are taken with my phone.
Old 12-14-2008, 07:24 PM   #23
Man, what idiot gave you that valve? There's a whole bunch'a valves that will
have a lower silhouette than that.
Robertshaw makes one.
Well pump control box delema freeonthree Electrical 36 11-02-2008 09:55 AM
SEWER BACK UP, Which Flood Control Good????? diyjt5259 Plumbing 1 10-08-2008 10:44 AM
control 4 switches gooch Electrical 3 01-03-2008 08:05 PM
