Old 01-07-2008, 06:22 PM   #16
Removing Extended Plenum
Originally Posted by Calm_Blue_Ocean View Post
Incidentally redline, I didn't mean to suggest I would need to reduct the entire house to put in an attic furnace...
The current arrangement is fine.
You may be able to install a controlled damper for the incoming air. When either the HWT or the furnace comes on then the damper opens to supply outiside air.
redline is offline   Reply With Quote
Plenum - Where to buy? zootjeff HVAC 1 07-11-2007 09:21 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
removing knockdown texture K_I37 Painting 7 05-07-2006 02:23 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
