Removing An Existing Heating Zone - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2007, 03:13 PM   #1
Removing an existing heating zone
During an addition I had plumber add a heating zone, that later I realized that I did not really need. The older thermostat is in the former master bedroom on the other side of the house. I would like to eliminate the that zone and use the thermostat in the new master bedroom.
Is it something a fairly capable homeowner/handyman could do?
chuckjon130 is offline   Reply With Quote
Old 11-09-2007, 04:46 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
A competetant DIYer should be able to do this.
There is more to it than you may realize, however. There's a maximum delta for the return water. You don't want the return water to be too cool or you'll get condensate on heat exhanger. Not good for a conventional boiler. The easiest solution would be to just wire both zones to the same thermostat.
I tear things down and build them up.
Last edited by Clutchcargo; 11-09-2007 at 05:01 PM. Reason: another option thought of
Clutchcargo is offline   Reply With Quote
3 zone thermostat moggi1964 HVAC 7 02-02-2012 10:21 AM
Underfloor heating existing tile floors armyguns HVAC 2 11-13-2007 07:19 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
Heating zone heats some unused rooms ChessMan General DIY Discussions 2 11-10-2004 01:36 PM
