Removing The Cover Of The Freedom 90 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 08:55 AM   #1
Removing the cover of the Freedom 90 Furnace
Folks,
This may seem a bit sad, but I am having the hardest time simply removing the front cover of my American Standard Freedom 90 furnace. Is there some trick I am missing? I had the gas company come start my furnace to begin the heating season last year, and it was ridiculously simple: once he got the cover off. I got the lower part out, but the top piece was latched on firmly. I don't want to pay $250 to have a guy come and follow the instructions that are on the front of the furnace. Who knows the trick to popping off the cover?
headhntr is offline   Reply With Quote
Old 10-03-2009, 12:24 PM   #2
Rewards Points: 1,654
Might try this link:
http://www.americanstandardair.com/H...DY_AUX_ADX.pdf
Not sure if this is your system but the door theory may be the same (be careful, the rest of the info may be wrong for your system!).
bob22 is online now   Reply With Quote
Old 10-03-2009, 05:39 PM   #3
as seen on tv
Rewards Points: 150
#1Turn power off #2 remove bottom door utilizing door latches #3 Lift up on bottom of top door and once over lip pull towards yourself this should remove upper door from bottom lip and guide door down and your off!
qbert is offline   Reply With Quote
Removing a Floor Furnace M.O.I. Flooring 3 10-27-2015 09:02 PM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-08-2011 11:33 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
