Old 03-05-2013, 08:43 PM   #1
Removing the back of baseboard
How the heck does the back part come off. I have been yanking it etc.
Mstrlucky74 is offline   Reply With Quote
Old 03-05-2013, 08:51 PM   #2
it is either screwed or nailed to the studs, maybe behind the coil or towards the bottom.
Old 03-06-2013, 06:55 AM   #3
Keep looking stop yanking .
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
joecaption (03-06-2013)
Old 03-06-2013, 07:00 AM   #4
If it's nailed just use a sawsall to cut the nails off.
Old 03-06-2013, 07:57 AM   #5
Super Moderator
Yep--screws or nails---just hope that the hardwood is not trapping the bottom---if it is,you will need to get creative---
Old 03-06-2013, 05:45 PM   #6
An old Tradesmen
Hope you drained the system before you started yanking.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
COLDIRON (03-06-2013), Mstrlucky74 (03-06-2013)
Old 03-06-2013, 07:23 PM   #7
Roofmaster
Having trouble with the window trim too? Make sure you cut the seam with a utility knife before you take your wonder bar to it.
" A lot of men build things, and a lot of things fall down "
jagans is online now   Reply With Quote
Old 03-06-2013, 07:31 PM   #8
Lol... Thanks
Didn't have the 'green thing' back in our day gma2rjc Green Home Improvement 6 07-05-2012 06:23 AM
Sump pump back up DennyF Plumbing 4 02-17-2012 02:58 PM
Baseboard Heater Size Advice nightheron Electrical 4 12-05-2010 08:33 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
