Remove Robert Shaw D34000 Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 12:38 AM   #1
Question
How does one remove an old Robert Shaw Quartz Movement D34000 Thermostat? It looks like it has survived since the mid/late 80s, but I don't see an obvious way to remove it for a modern replacement.
wanderlust is offline   Reply With Quote
Old 10-11-2011, 01:08 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
A pic would help. I just tried to google image that stat but nothing came up.
Doc Holliday is offline   Reply With Quote
Old 10-11-2011, 01:10 AM   #3
No hits on the Robertshaw website either.
Old 10-11-2011, 01:33 AM   #4
Thanks DH, you can view image here (first hit on Google Images for Robert Shaw D34000): http://www.askmehelpdesk.com/attachm...thermostat.jpg
It looks like there are tiny recessed screws that require a small jeweler-type screw driver.
Old 10-11-2011, 01:34 AM   #5
Old 10-11-2011, 09:28 AM   #6
Rewards Points: 6,652
Remove the three obvious hex head screws, and it should lift off.
Old 10-11-2011, 03:39 PM   #7
Yup, those three 1/4" hex head screws to be precise, are holding the sub base to the sheetrock. Nothing to it.
Old 10-11-2011, 04:27 PM   #8
Thanks all. My issue was actually getting the Controls off the subbase, but I got it this AM. Removing the subbase was easy and obvious as you've suggested. Sorry, that pic wasn't helpful as the controls had already been removed.
Tags
d34000 , quartz movement , robert shaw , thermostat
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 05:28 PM
Two heating systems, looking for one thermostat. Need help. CdoubleZ HVAC 1 02-12-2011 08:16 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 04:26 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
