Removal Of Old HVAC System - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2009, 10:42 AM   #1
Removal of old HVAC system
I am wanting to remove a functioning split heat pump system from a house and was wondering if it is a feasible diy job? There is still refrigerant in it and it still runs.
I am fine doing the electrical disconnections, but was curious as to how to go about sawing/disconnecting the refrigerant lines.
Thanks!
yakmo6 is offline   Reply With Quote
Old 01-16-2009, 10:52 AM   #2
Rewards Points: 1,548
Are you sure you want to decommission and remove the system?
I would have a professional come over and discharge the refrigerant. Do not saw apart the Freon lines. If you do it yourself and mess up, the Freon is under pressure and could spatter all over the place and give you frostbite if it gets on you. Can cause eye damage.
Old 01-16-2009, 10:57 AM   #3
Home Air Direct's Avatar
Not a DIY project. Unless you have the ability (tools) to reclaim and are licensed to do so, hire a pro.
I am a huge fan of DIY, but this is not the area you need to try and save money on.
Cutting refrigerant loose into the atmosphere brings a $10,000 fine.
DIY by calling a tech yourself.
Jay
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 01-16-2009, 10:59 AM   #4
Rewards Points: 1,910
I'm pretty sure the EPA would fine you big time if you released freon (like $10 grand or so). I think you need a licensed HVAC guy to pump out the freon. After that you can have at it.
Old 01-16-2009, 01:33 PM   #5
Rewards Points: 502
When I took my old system out, I closed the liquid line at the outdoor condenser and let the compressor suck it all into the condenser. With it running, I could hear the compressor sound change. After several minutes, I closed the suction line and proceeded to disconnect the copper lines.
There was no loss of any refrigerant from the system, no hissing, etc.
I then sold the old system to a guy who had to add just a little to his installation because of his lineset being longer.
I did this at the recommendation of an HVAC contractor. (prior to knowing there is a fine of 10k)
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-16-2009, 02:17 PM   #6
Thanks for the great input. I'm probably going to call a tech to do the job, as the equipment is still under warranty and I don't want to void it. I thought if it was a simple process that I might have at it, but it sounds like there's just too much to risk.
Thanks again.
Old 01-16-2009, 03:50 PM   #7
An old Tradesmen
Rewards Points: 8,202
Actually, its not a $10,000.00 fine.
Never was.
It started at $25,000.00, its now over $30,000.00
But a judge can lower it.
Old 01-16-2009, 04:37 PM   #8
Rewards Points: 292
Thanks again.
Were you planning to move it within your property? I'm not absolutely sure, but I believe that a warranty is voided if the equipment (furnace or condenser) is moved.
V
veesubotee is offline   Reply With Quote
Openings in air intake duct on central HVAC system Omegazz HVAC 5 04-01-2010 12:59 PM
HVAC system down? dutchmaster HVAC 2 12-03-2008 04:30 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Insulating an attic for HVAC system BigJimmy Building & Construction 7 10-07-2006 09:10 PM
