Relocate Steam Radiator Piping - HVAC - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 10:29 AM   #1
I have a one-pipe steam heating system. The main steam line runs on the left side of the basement and the supply lines branch off and also go up to the radiators on the left side of the house. I want to move one of the radiators on the first floor from the left side of the kitchen to the right side of the kitchen. So I basically want to turn the pictured branch line 180 degrees in the basement so it can go up to the new radiator location on the right side of the house.
Can I do this and will it unbalance the steam system?
Supply Line I want to move to other side
rickr86 is offline   Reply With Quote
Old 03-12-2013, 10:31 AM   #2
Rewards Points: 13,732
No pictures came up just a bunch of code.
Old 03-12-2013, 10:36 AM   #3
fixed now, thanks
Old 03-12-2013, 11:21 AM   #4
Next Time...New Build
Rewards Points: 150
I don't really think you would have a balancing issue since you are not adding/subtracting any lines.
The biggest thing to remember would be to pitch the pipe correctly so the condensed steam can get back to the boiler appropriately.
I have the same setup and have often wondered the same thing. Your move looks pretty straightforward and with a few new fittings could be done rather easily.
I am certainly not a plumber and finding qualified people to answer one pipe steam questions seems to be getting tougher and tougher. However, I think it can be done.
RickyBobby is offline   Reply With Quote
Old 03-12-2013, 11:26 AM   #5
Yes the pitch is important- Thanks
Old 03-12-2013, 07:48 PM   #6
REP
I was once told that you could heat a department sore on a 1/2 lb of steam.What you want to do is perfectly fine.Size of pipe and pitch are all important.You could even for father than 5' if you had to as long as pitch and size was right.
REP is offline   Reply With Quote
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
Plumbing for shower and steam generator Smitny22 Plumbing 10 02-20-2012 05:19 PM
Steam engines Red Squirrel Green Home Improvement 8 04-24-2011 05:59 PM
Seals on steam shower doors hacksepe Building & Construction 1 04-22-2010 05:13 PM
Steam to Hydro Air Conversion RBR HVAC 1 09-17-2009 04:23 PM
