Relocate Ac Comressor - HVAC - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 07:10 PM   #1
Relocate ac comressor
Hi all, first time out so be a little tolerant. I am looking out my window at a 10+ year old ac compressor that really needs replacing. The existing location is terrible as it is in a front courtyard, viewable from the street and within a few feet of the front entrance. I would like to move it to the side yard on the east side of the house. Since the house is build on a slab and I don't have an attic on that side I though that the easiest/best method would be to run the wires and pipes underground through (2) 3/4" conduits and a 2 or 3 inch abs pipe for the refrigerant lines. The total distance underground is less than 50' and about 10' to the air handler. As I am retired and on a limited budget I would do the digging (which oddly enough I don't mind, actually enjoy) and maybe even pull the wires. Is this (going underground) a stupid idea??? Thanks in advance, G
Gretagerm is offline   Reply With Quote
Old 04-19-2009, 07:34 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
It is not a good idea and the whole job would be VERY expensive to do. It may take 4-6 hrs plus freon, nitrogen test, copper tubing etc etc. My company would charge $600 to $1000 plus taxes to do it. It is not easy to bend large freon lines tightly and if you have elbows soldered in, it takes more time and there is a chance for leaks.
Old 04-19-2009, 08:42 PM   #3
An old Tradesmen
Rewards Points: 6,590
The lines would need a lot of insulation.
And the pipe the lines are ran through, would need to be sealed to keep water out.
I can be done. But, you can lose capacity. And care must be taked to prevent refrigerant migration and oil slugging.
Old 04-20-2009, 08:04 AM   #4
New
New high eff units are quite, you should consider installing one in the same location with scalloped cinder block wall around it leaving enough room for service and air flow.
SULTINI is offline   Reply With Quote
Old 04-20-2009, 06:56 PM   #5
Mini-Split
hvaclover is offline   Reply With Quote
Old 04-21-2009, 06:11 AM   #6
Confused
I think you answered the wrong post.
Relocate shower drain in concrete devouru Plumbing 16 10-03-2015 03:56 PM
Shower drain relocate fireman74 Plumbing 3 12-30-2008 12:46 AM
Extra wall register in bedroom: seal up or relocate? pmoe HVAC 5 12-08-2008 10:57 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
relocate washer/dryer krtw Remodeling 2 01-15-2006 03:39 AM
