Relay Help - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 08:36 PM   #1
Relay help
Hi all. I am new to the site and in need of advice. I need to identify what type of relay is pictured in this wiring diagram for the IDR inducer relay. It's 24v coil relay, but I don't know what pole or throw is required. I think it could be a SPDT NO NC relay??? Any help is appreciated.
Cody
cody69 is offline   Reply With Quote
Old 02-10-2011, 06:53 PM   #2
Houston204's Avatar
Rewards Points: 556
http://www.marsm-a.com/images/catalog/c-56.pdf
It is a DPDT relay. The Mars 90340 , Honeywell R8222D1014 or White Rodgers 90-340 would work.
Houston204 is offline   Reply With Quote
The Following User Says Thank You to Houston204 For This Useful Post:
cody69 (02-16-2011)
Old 02-10-2011, 07:38 PM   #3
Its not a DPDT is a SPDT both NO and NC contacts share the same contact common.
atatarian is offline   Reply With Quote
The Following User Says Thank You to atatarian For This Useful Post:
cody69 (02-16-2011)
Old 02-10-2011, 07:40 PM   #4
my bad I was looking at the bmr relay it is DPDT sorry
cody69 (02-16-2011)
Old 02-11-2011, 07:08 AM   #5
Retired Electrician
ITS A DPDT relay
fy171 is offline   Reply With Quote
The Following User Says Thank You to fy171 For This Useful Post:
cody69 (02-16-2011)
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
Electric Baseboard Heat - relay problem? sporkman HVAC 7 11-21-2010 06:43 PM
Relay controlled baseboard heaters a7ecorsair Electrical 6 06-20-2010 01:31 AM
Heating relay wiring Toledo Electrical 6 11-26-2009 12:03 PM
newbie...relay problems jfabes Electrical 11 05-06-2008 04:48 PM
