Relay On Heat Pump Control Box Making Clicking Sounds - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 09:00 AM   #1
Relay on Heat Pump control box making clicking sounds
I got a Trane Heat Pump unit that is around 19 years old. For the last few days the relay located in the box located inside the house is been making an horrible clicking sound. I went to the garage and pull guard duty on the relay and when the outside unit calls for emergency heat (gas) due to being too cold outside, the relay is having a hard time making firm contact and it switches on and off very quickly, creating some sparks within the relay. After that a normal click sound is heard and the gas fires up and goes but not for long. I will buy a new relay today and replace it but I'm afraid that I will be addressing the consequence instead of the cause, thanks in advance for all your help. The unit is an XE80 in the inside and a XE1000 outside.
berr3555 is offline   Reply With Quote
Old 02-02-2013, 09:28 AM   #2
An old Tradesmen
Rewards Points: 6,132
Are you talking about a relay in a dual fuel relay box.
Old 02-02-2013, 09:42 AM   #3
I attached a pic of the relay, also when it does its clicking it makes the lights in the house flicker a little.
Relay on Heat Pump control box making clicking sounds-20130202_083454-2-.jpg
Old 02-02-2013, 09:58 AM   #4
Also when running the unit in emergency heat it doesn't have any issues.
Old 02-02-2013, 12:27 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
Sounds like a good time to upgrade from that tayplus kit to a dual fuel capable thermostat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
berr3555 (02-02-2013)
Old 02-02-2013, 12:50 PM   #6
An old Tradesmen
While it could be that ice cube relay. More likely its a wire connection in the outdoor unit.
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-02-2013, 01:14 PM   #7
I went ahead and replaced the relay. I made a quick visual inspection of the old relay and it looks fine (not burnt marks). Now I got to wait until tonight or tomorrow morning (too warm outside right now) to see if that solved the issue.
Old 02-02-2013, 01:27 PM   #8
I've looked at some thermostats in Lowes and it seems that het pumps installations might be out of my abilities. I might be able to do it with a lot of patience and time to troubleshoot.
Old 02-22-2013, 07:57 PM   #9
It finally got cold enough and it sis it again, when the outside unit calls for heat the relay in the previous post goes crazy trying to make contact. It seems that is not getting enough juice in the winding of the relay to keep it firmly engaged. Tomorrow I will take the outside unit and see if there is any obvious defects in the wiring or connections. Also, its being about a year since I replaced the 24V transformer, the contactor in the outside unit was burning them up. Any suggestion on what I should be looking for its greatly appreciated.
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 09:07 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
