Reheem Fernace Not Igniting - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2008, 03:45 PM   #1
Okay I have a rheem furnace and it was working fine just a couple of days ago. Yesterday I woke up and it was 57 degrees in my house and I could hear the exhaust motor running on the furnace but there was no air coming out of the vent and the burners were not on. I checked a few things and determined that it must be the vacuum switch.
I decided to replace the thermostat to match my other one before I bought a new vacuum switch just to rule that out and now the blower motor and the exhaust motor will come on at the same time and about 30 second later I can see the igniter glow but still no gas and no flame. Is the gas valve bad, or is there another problem?
erc1956us is offline   Reply With Quote
Old 11-06-2008, 06:01 PM   #2
An old Tradesmen
Rewards Points: 6,470
Don't know.
But you probably have something wired wrong that the blower comes on now, but didn't before.
Old 11-07-2008, 08:38 AM   #3
Its okay to upgrade your equipment but I would hold off on doing that for when the system is working right. Wire you old tstat back up and verify everything is behaving as before. Next check you temp sensor as that is part of your ignition sequence.
dac122 is offline   Reply With Quote
Tappan not igniting jholder73 HVAC 1 10-23-2008 01:59 PM
furnace not igniting jjoossee25 HVAC 3 12-04-2006 06:01 PM
