| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Change an Exhaust
by Expert Village
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Okay, let's install exhaust. We've got an engine, we've got a fuel supply there, a little bit of... Read More »
How to Buy Septic Field Tubing
by eHow.com
Knowing what type of septic field tubing you need for your leach field is important. Selecting the size, type and configuration of pipe can mean the difference between your leach field working and having it fail. To be sure you have the right pipe for... Read More »
Removing Manifold From Air Conditioning Compressor in a Ford Explorer
by Expert Village
Today we're changing an air conditioning compressor on a '96 Ford Explorer. In this step, I'm going to demonstrate the proper service procedure for removing the manifold from the back of your air conditioning compressor. The AC manifold is located right... Read More »
Installing Exhaust Headers on a Custom Car
by Expert Village
Hi! I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now the muffler is correctly mounted. We need to run exhaust pipes to get to the muffler. Here are... Read More »
Cracked Cylinder Diagnosis: Remove the Intake Manifold
by Expert Village
Remove the intake manifold, making sure to get the seal between the intake manifold and the cylinder heads and cylinder block to break loose; learn how in this free auto-restoration video. Read More »
