Regular Vent Pipe->type B Adapter - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 12:47 PM   #1
Rewards Points: 1,062
regular vent pipe->type B adapter
how do you fit the regular vent pipe into the regular->typeB adapter? i am confused because the regular side of the adapter has two walls but they are spread apart kind of like the female side on a regular type B fitting. if i take a crimped end of a regular pipe, it will fit inside the inner loop but if i take an uncrimped end, it fits in between the two walls. i am inclined to think the latter is correct. just checking cause i wanna be 100% sure my gas venting is done right.
thanks
Old 11-03-2011, 01:35 PM   #2
30 year tech
hvac122's Avatar
Crimped ends go towards the outside. A crimped pipe goes into the inner liner of the double wall pipe.
hvac122 is offline   Reply With Quote
Old 11-03-2011, 02:35 PM   #3
REP
Hvac122 is correct.The fitting you are discribing is made so that one brand of "B" vent can mate to another brand of "B" vent,sonce differant brands have differant connection designs.
REP is offline   Reply With Quote
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Water leaking from vent pipe die_of_ennui Plumbing 3 03-25-2010 09:11 AM
Hot Water Heater Improper Vent Pipe Danger fritzycat1 Plumbing 2 07-27-2009 11:34 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
