Regular->type-B Vent Adapter - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 03:06 PM   #1
Rewards Points: 1,062
Question
regular->type-B vent adapter
both my water heater and radiator boiler, both of which are natural gas, have non-type-B exhaust outlets, i.e. regular single wall. since i am supposed to use type-B, i was wondering if i can just get away with fitting type B onto them (which does fit) or does that present some CO hazard and i should rather use some sort of an adapter that would seal the thing. in the first, more convenient scenario, i was gonna maybe just wrap the joint with some aluminum self-adhesive tape like it's used for regular ducting.
e.g. something like this:
http://www.ventingpipe.com/duravent-...baid=945672437
thanks
Old 09-21-2011, 05:15 PM   #2
Rewards Points: 1,216
Type B vent is the double wall vent that your water heater and heater go into, you would use smoke pipe single wall from the appliances to the B vent make sure you observe all clearances.
COLDIRON is offline   Reply With Quote
Old 09-21-2011, 05:47 PM   #3
RTV/high temp silicone if need be.
Old 09-21-2011, 09:01 PM   #4
The part you're looking for is called a b-vent draft hood connecter. It's a short section of b-vent with the inner wall extended down past the outer wall. May as well make your job look professional.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
amakarevic (09-21-2011)
Old 09-22-2011, 07:21 AM   #5
Tip; When you install your single wall pipe to the B vent make sure your joints follow the direction of flow of the flue gas. Just do a neat job with screws no tape required.
Old 09-22-2011, 02:38 PM   #6
hey fellas, here is another question i posted, kind of related, i'm sure y'all are familiar with the subject:
Type B vent M/F end vertical positioning
much obliged
Old 09-22-2011, 06:53 PM   #7
Rewards Points: 95
Just curious about the clearances. My understanding is that it's 16" for single-wall vent and 1" for B-vent, is that right?
garya505 is offline   Reply With Quote
Old 09-22-2011, 09:54 PM   #8
C-vent (Single wall) is 6", B-vent (double wall) is 1".
Old 09-22-2011, 11:37 PM   #9
Rewards Points: 95
Well, I was only off by '1'.
Old 09-22-2011, 11:40 PM   #10
Question
is there such a thing as A-vent?
Tags
venting , venting pipes
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 03:39 PM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 01:34 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
