Regular Foil Ducting Tape - HVAC - DIY Chatroom Home Improvement Forum
Old 07-15-2009, 09:32 PM   #1
Rewards Points: 1,088
Is there something better than foil ducting tape to secure insulation onto the metal airhandler in the attic? Some of those flex ducts in the attic have large diameters, and it's just hard to get the tape to stick? Anyone have a special taping technique that they use?
Also, it seems that during the cooling season, you can feel the air coming out of the sides and openings in the airhandler, but during the heating season, you can't. Has anyone noticed this?
handy man88 is offline   Reply With Quote
Old 07-15-2009, 09:43 PM   #2
have you looked into taking some hvac courses? They would help you quite abit.
Use a good quality duct tape or a foil tape rated for hvac use.
hvaclover is offline   Reply With Quote
Old 07-15-2009, 09:58 PM   #3
I'm just a DIY'er...
Old 07-15-2009, 10:19 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
Your fan runs on a higher speed for A/C and higher pressure than heating. Metal foil tape sticks very well if you are patient and careful with it. We use it for HRV's etc.
Old 07-16-2009, 12:01 AM   #5
Rewards Points: 260
Use spray adhesive first. Also, make sure you use a rub to apply the tape. Some call it a squeegee. It is just a plastic tool to apply the tape. Foil tape has a hard time sticking to some air handlers. I think there is oil residue on the sheet metal. You can follow up with mastic to completely seal it.
bluefitness is offline   Reply With Quote
Old 07-16-2009, 04:41 PM   #6
Great suggestions guys.
Old 07-16-2009, 04:44 PM   #7
Didn't know you used spray adhesive for foil tape. We only use metal here for ducts.
Old 07-17-2009, 04:39 PM   #8
Rewards Points: 260
Spray adhesive is only used when the duct board is dirty/old or when it has a hard time sticking to an air handler. Goodman units seem to have a film on them.
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
using caulk instead of tape on hairline cracks.. windowguy Painting 2 04-15-2009 11:27 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 10:27 PM
Tape for duct work? Willie5566 HVAC 4 01-16-2007 05:02 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
