Registers Stuffed With Old Clothes? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 12:34 PM   #1
registers stuffed with old clothes?
Hi I recently bought a fixer upper house and the house has hvac vents is the cieling which are what is being used. In everyroom there are baseboard wall type vents with old clothes stuffed in them. In one room I could see daylight through one, on the outside of the house is a mesh screen covering the hole with clothes in it . Can I clothes all these off and insulate? The house is a single story with a crawl space under the entire house and an attic above. I'm not sure if there is supposed to to be a purpose for the vents or if they're just old non used ones. Thanks
afrederic2 is offline   Reply With Quote
Old 01-10-2012, 12:56 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Off course you can close them off but you may need an actual flooring guy to help patch those up.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-10-2012, 12:57 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,764
Post some pics. It is possible they had an old horizontal oil furnace or other heating system under the house with those floor vents and now converted to an air handler with electric heat strips inside the attic. May want to get it checked by a Pro for safety reasons and normal maintenance and he can help you too.
Adding to registers to existing hvac system amugable HVAC 2 07-22-2011 06:07 PM
Heat Registers: stamped vs.adjustable joside HVAC 0 11-10-2010 01:59 PM
Adding heat registers to basement brick1930 HVAC 0 08-24-2009 05:52 PM
Ceiling mounted clothes rod (one side wall mount, one side ceiling mount) DCA General DIY Discussions 9 08-17-2009 10:13 AM
Baseboard moulding taller than air registers interplexr Remodeling 8 04-03-2009 06:24 AM
