Register Size? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 10:11 PM   #1
register size?
Is there any diffrence in flow between 12x6x6 registers and say a 14x8x6 register being that the inlet is the same?
sjthompson is offline   Reply With Quote
Old 09-03-2010, 08:25 AM   #2
fabrk8r
fabrk8r's Avatar
Can you please explain the dimensions you used?
Most registers are dimensioned as Width X Height.
I don't know what the third number in your dimensions is.
As far as resistance to airflow, unless it is an extremely odd shape, the real factor is blade type, degree of throw, and whether there is a damper in the register assembly. It is also important that there is a section of straight duct before the register, which is sometimes hard to accomplish.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-03-2010, 08:27 AM   #3
fabrk8r
fabrk8r's Avatar
I see now, the third dimension you gave is the pipe diameter. Gotcha!
No, with the examples you gave there would be no perceptible difference in air flow provided that the transition from square to round isn't too radical.
Old 09-03-2010, 07:36 PM   #4
An old Tradesmen
Rewards Points: 7,372
The larger register will have less throw at the same CFM. Meaning a larger floor register won't throw the air as high. So you get less air mix.
A wall register may not throw the air as far, and end up not mixing as well at the far wall.
The Following User Says Thank You to beenthere For This Useful Post:
fabrk8r (09-03-2010)
Old 09-03-2010, 11:26 PM   #5
oh I see so stay 12x6 and the throw will be further the larger the duct same throw but more spread of air I guess. I can't go 8" on the living room lines but I could pull 7's off. Let me ask this though What if I have my 8" or 10" split into 2 7's but reduce them right into the exsisting 6' register will I still get more flow then?
Old 09-03-2010, 11:39 PM   #6
her is a pic of my system
Old 09-03-2010, 11:44 PM   #7
a few more
Old 09-04-2010, 02:56 AM   #8
An old Tradesmen
Reducing to 6" just before, or at the register will tend to nullify the increase in duct size. The extra turbulence of the reducer right at the boot causes it.
Does Register Size Matter? artlover13060 HVAC 6 07-16-2010 07:46 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
heating register size ponch37300 HVAC 3 02-18-2009 09:48 PM
Register Boot size? Arnj HVAC 8 01-30-2009 07:47 PM
Return Register Size for 16" Flex hartkem HVAC 17 11-15-2008 11:13 AM
