Register Not Connected To Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 08:27 PM   #1
Rewards Points: 59
Question
Register Not Connected to Duct
My 100+ year old house has a retrofitted HVAC system that appears to have been improperly installed. In addition to a register that has no air flow altogether, I have discovered a register that is not directly connected to the duct. Any suggestions on making the connection? Buy scrap ducting and craft a "box" to bridge the divide? Tear off the drywall to access the duct and rebuild it? I tried Googling for advice/techniques but could not find the right combination of terms to render results...
gnikyerffej1 is offline   Reply With Quote
Old 07-31-2013, 09:48 PM   #2
Rewards Points: 6,652
Are you sure that it is not a return?
Old 08-01-2013, 06:57 AM   #3
Rewards Points: 12,794
Without a picture of where it's disconnected, it's hard to suggest how to fix it.
With the system running take a piece of toilet paper and see it sucks up to the register. If it does then it's a return vent and should not have air coming out of it.
Old 08-01-2013, 05:52 PM   #4
With that old of a home, the register may have been part of the original heating system, and is now abandoned.
RoyalAcresRod is offline   Reply With Quote
Old 08-02-2013, 02:18 PM   #5
Rewards Points: 59
100% positive this is a register and not a return. It's a retrofitted HVAC, enclosed in sheetrock. There is probably a 1-2" gap between the sheetrock and duct.
Old 08-02-2013, 03:07 PM   #6
MarginallyQualified
Rewards Points: 2,464
The --joint sealed, insulted and supported-- *duct* should be attached to a *boot* which is attached to the wall/ceiling framing.
Then, in turn (after the walls are finished and painted etc) the *register* slips into the boot and then is fastened to the same wall framing the boot is secured to. Anything short of this is inadequate.
Some pictures to browse through HERE
Try to identify what your problem is.
If you still need help... ask.
Old 08-02-2013, 08:36 PM   #7
Experienced HVAC Tech
HVAC1000's Avatar
Can we have some pictures please
HVAC1000 is offline   Reply With Quote
The Following User Says Thank You to HVAC1000 For This Useful Post:
ben's plumbing (12-22-2013)
Old 08-11-2013, 07:52 PM   #8
Rewards Points: 59
Talking
So there is no boot between the register and the duct. Any thoughts?
I am considering positioning a box "saddle" between the two, as tearing down the duct is not an option. Another option might be to seal the existing duct and insert a boot at a different spot.
Old 12-22-2013, 05:37 PM   #9
Rewards Points: 59
Updated with photographs...
Finally had the opportunity to take some photographs. As you might/might not be able to see, there is a good 1-2" between the duct and the drywall.
Old 12-22-2013, 07:29 PM   #10
Trucon01's Avatar
Rewards Points: 510
Eeek. I'd be concerned that you have a 220 line resting on the jagged edge of your duct work...
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 12-23-2013, 01:27 PM   #11
Rewards Points: 59
Yes, most definitely a compounding factor though something I can secure. The question becomes how to conjoin the existing duct to a vent.
Old 12-23-2013, 05:07 PM   #12
Rewards Points: 1,630
That's an awkward place to work, and I would probably use roofing tin. It comes in a roll and usually 4 or 5 inches in width. Pretty easy to work with. You can almost cut it with normal scissors. Use pop rivets to connect with the existing duct work, and you may even want to follow that up with a bit of foil tape for a positive seal. Bring it out about 1/4 inch past the finished wall, slice the corners, then fold it back against the wall and tack it.
Bob Sanders is offline   Reply With Quote
Old 12-24-2013, 09:28 AM   #13
biggles's Avatar
test fit...take apart a good sized cardboard box shape it into that opening 4 sided..seal with tape to for the box shape... to the back .so now you have a box sticking out of the opening inside that riser,...cut it 1/2" out from the sheet rock bend it back so the register covers that bend...when mounted... if the air is coming in at the 6 oclock area of that cardboard box your looking into cut it open with a razor...aluminum fabric duct tape to seal that card board collar.....just a thought.... I would check all your discharge air supplies for true air no leaks and god knows what the returns look like,you need to return the conditioned space air sucking and supply the most discharged blowing out heated air into the space...
Old 12-24-2013, 01:44 PM   #14
Rewards Points: 59
I poked at this again today, here is what I am thinking:
1. Remove the vents, relocate any serious electrical hazards
2. Trim the existing metal edges
3. Seal the existing holes with galvanized flat sheet, riveted closed
4. Use foil tape to finish seal
5. Further down the riser, cut a large hole the sheet rock
6. Cut a hole in the existing duct and connect a standard register box
Questions
1. Probably best to use an 8" hole saw to get the right cut?
2 How to connect the round end of the register box to the duct?
It seems the alternatives proposed aren't going to create a tight seal...I'm working with something that is seriously rigged.
The Following User Says Thank You to gnikyerffej1 For This Useful Post:
gregzoll (12-24-2013)
Old 12-24-2013, 02:22 PM   #15
An old Tradesmen
Rewards Points: 6,072
Looks like a return. Is it a return or supply.
How to clean un-lined round duct board?? a1481155 HVAC 4 05-08-2013 05:52 PM
Duct Fan Relay Question Burbman HVAC 4 03-13-2013 08:34 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 11:50 AM
Doing a dryer duct, the right way... nowwhatnapster HVAC 7 01-30-2013 08:52 PM
Duct Routing clayman HVAC 3 11-11-2010 06:48 PM
