Register Box In Dropped Ceiling - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 10:52 AM   #1
Register Box in Dropped Ceiling
I'm trying to find a register box similar to this one: http://www.homedepot.com/webapp/wcs/...ctId=100197347
That has "ears" in order to screw the grill on the down side of the dropped ceiling panel to it. A contractor that worked on another part of my basement installed one but I think he gets his parts from a HVAC supply place, the typical big box stores don't have them. Anyone know where I can get them?
trestlew is offline   Reply With Quote
Old 01-14-2013, 02:26 PM   #2
i used to see a lot of hvac guys screw 1x2 to the boot to hold it and also have something to screw the register to. you could also bend a flange on the boot yourself. i have seen them screw the metal angle they use for returns on a boot also. if you absolutely need one try a heating and cooling supply
Old 01-14-2013, 02:40 PM   #3
Yeah what I was going to do was snip the ends of the box and bend them out to scew to. Thanks for the info Danny.
Old 01-14-2013, 11:11 PM   #4
firehawkmph's Avatar
Rewards Points: 1,800
Trest,
I go to a local heating supply company that has their own shop in house. They bend up anything I want. They usually supply separate L-shaped tabs (ears) to fasten to the ends of the boot.
Mike Hawkins
firehawkmph is offline   Reply With Quote
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
More Dropped Ceiling fun markronz Remodeling 11 03-07-2010 04:11 PM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 06:26 AM
Soffit Running Thru Bathroom / Dropped Ceiling xlr8tn Building & Construction 3 01-23-2008 07:37 PM
