Old 01-25-2009, 02:05 AM   #1
Default Register Boot size?
I am running 10'' for hot air and 12'' for return air inside from a outside wood furnace, my question is what size of register boot do I need for both of them? I know it will be 10'' and 12'' but by what 10'' X? X? and 12'' X? X? ?
Arnj is offline   Reply With Quote
Old 01-25-2009, 08:09 AM   #2
An old Tradesmen
That depends on what BTU rating the wood stove is.
And what air flow they want for it.
Old 01-25-2009, 04:07 PM   #3
They do not list a BTU rating they say there are to many variable factors that can change it . In the manual it says it has a 1800cfm blower and it should have 600 feet to 1000 feet per minute in the main duct and 400 to 600 FPM at the registers. Does this help any?
Old 01-25-2009, 04:20 PM   #4
Dr Heat's Avatar
As a general rule of thumb I like to see terminal boots to have 2X the area of the duct this is to allow for the register and the block that it creates.
Now this being a wood furnace better to go large and let the fan move as much air as possible.
10" round = 9x9 sq.
12" round =11x11
So Your 10" trunk would terminate at about 8x20 the 12" 10x 24
These sould put you in the ball park.
Dr Heat is offline   Reply With Quote
Old 01-25-2009, 04:39 PM   #5
Thank you DR HEAT. I found the BTU rating on the furnaces website it is maximum 200,000 I dought this will change the boot size any, but just thought i'd list it. Thanks again
Old 01-25-2009, 09:23 PM   #6
An old Tradesmen
1800 CFM at 1000 FPM, requires an 18" round duct.
If you use 10", you ain't getting much heat out of that wood furnace, before it shuts down.
Your going to need some really big grilles also.
Old 01-29-2009, 02:36 AM   #7
Does anybody know who makes a 8'' x 20'' heat register ? The biggest I can find is a 8x14.Or would it be alright to just use a return grille? I do find them in that size.
Old 01-30-2009, 09:44 PM   #8
Dr Heat's Avatar
Ya I missed the 1800 cfm
Old 01-30-2009, 09:47 PM   #9
Dr Heat's Avatar
You might need to go to a commercial grill, special order from continental.
Return grills are different they are not designed to distribute the air.
More On This Topic
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Extra wall register in bedroom: seal up or relocate? pmoe HVAC 5 12-08-2008 11:57 PM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 10:07 PM
Proper installation of register boot hartkem HVAC 5 11-16-2008 12:44 AM
Return Register Size for 16" Flex hartkem HVAC 17 11-15-2008 01:13 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 07:26 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
