Old 11-08-2009, 08:20 PM   #1
Still Learning
Refrigerator not cold but freezer is
Im trying to figure out why the freezer is cold but the fridge is not. the indoor coil freezes up over time. Could it be the defrost timer or the can motor? it is a GE fridge. Does anyone know how to test the defrost timer to see if it is good?I will tear apart the inside to see if the evaporator fan motor is running.
thehvacguy is offline   Reply With Quote
Old 11-09-2009, 07:08 AM   #2
An old Tradesmen
If the freezer gets cold, but not the fridge, its generally not the defrost timer.
Either fan, or your low on charge.
Old 11-09-2009, 09:15 AM   #3
If the coils are freezing up it is possible the defrost timer has malfunctioned -- in the on position. Sometimes a screwdriver adjustment for the defrost timer is on the back so you have to pull the 'fridge away from the wall to inspect the timer. A malfunction can generally be determined when the screwdriver adjustment is not seen to rotate by itself over a period of several hours.
The purpose of the screwdriver adjustment is to get the 'fridge cooling more quickly after a power failure if the timer happened to be in the off position which normally lasts about an hour.
Many refrigerators have separate main and freezer compartment adjustments. Most of the time these are louver adjustments that need trial and error to get positioned properly.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 11-09-2009, 03:40 PM   #4
hvaclover's Avatar
EEEEHHHHHHHHNIT .....wrong
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 11-09-2009, 03:46 PM   #5
hvaclover's Avatar
Worked on frost free friges since '77.
It is either a timer, defrost terminator, or a heater (rare but happens) that is not working.
We would test the heater with an ampmeter. Reading shows it's ok.
Timer could stick or the terminator switch would shut off heater too soon allowing intermittent frost up of evaporator.
Old 11-09-2009, 03:56 PM   #6
An old Tradesmen
Bet its not the defrost timer.
We'll see when he tells us what he found.
Old 11-09-2009, 04:36 PM   #7
hvaclover's Avatar
Bet it's the terminator AND timer cause that has been an idiosyncrasy of GE defrost systems for years.
Old 11-09-2009, 04:44 PM   #8
This happened to me. I have a Kitchenaid side by side. It was the air transfer gate between the freezer and refrigerator side. The frig side is cooled from air from the freezer. There is a computer controlled gate that opens and closes to regulate the frig temperature. Mine was at the top, back of the freezer/frig wall. It broke. I replaced it easy enough.
bmesc is offline   Reply With Quote
Old 11-09-2009, 07:47 PM   #9
Need a model no, but I"m bettin on the heater. GE's weak point forever
d scott is offline   Reply With Quote
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Freezer not cold enough trupok Electrical 2 08-14-2008 10:51 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
